CLOSED TPS SETTING
closed tps (meaning no throttle)
access the bosch system in the MPEM programmer, then select "adjustment" in the sub menu, choose "close tps" in the adjustment menu ....screen will display
the actual adjustment of the tps and will also offer to adjust it
AT THIS POINT< DO NOT SELECT YES , UNTIL IDLE SCREW IS LOOSENED, AND IDLE SCREW IS LOOSENED UNTIL THROTTLE PLATE IS COMPLETELY CLOSED .....
now, goose the throttle a few times, and make sure it is completely closed ....
now, select yes and it will automatically adjust the closed throttle setting to the new setting ....
NOW,
access the bosch system, in the MPEM programmer, THEN SELECT REAL TIME...(in the sub menu), and turn your idle screw approx 2 turns, and watch the tps setting till it reaches 6 or 7 degrees , this will approximately make your idle speed correct, (it will need to be set in the water at approximately 1500 rpms give or take 50 ....
now, this is the procedure, read it over a few times, before you ever try and do it ...i always read people say its like 4 degrees, mine is like 8 degrees, well, if it is, something is wrong, or you didn't switch programmer to real time,
after the first part is achieved, and you switch screen to real time, ...YOUR CLOSED TPS SETTING IS DONE. ...the 2 turns and 6-7 degrees always confuses people, and it is there to let you put an allen head socket in 1 hand, watch the screen till you get to 6 or 7 degrees, and have a basic preliminary setting .....
now, this being said, i am not ever going to type all this out again, so, you all can copy and paste it and save it your notes ......
