its ok to jump your ski from another battery, provided other ski, or vehicle is not running, after all, 12 volts is 12 volts, i have never unplugged my rectifier from ski to charge battery, but, i will never start my ski with a battery charger hooked up, the maintainer i use is just a 1.5 amp maintainer http://www.walmart.com/ip/Schumacher-Automotive-SpeedCharge-Battery-Maintainer-and-Charger/13005742
this is all anyone really needs, i use it on riding mower, 4 wheeler, its always hooked up on something, if you're not gonna use ski for an extended period of time, i'd recommend to just unhook the negative (black) battery cable and hook up your maintainer, (if you are using a big charger , unhook battery also) --- you should fix your loose connection though, and quit unplugging it right there,
the impeller issue, here is a chart from solas, i like their impellers, have some friends with some fast skis that have them, mine is stock though, if i was going to change, id just go with some (mid range) inpeller, unless you have a built ski (engine with mods), http://impros.com/charts/solas_seadoo.html
also on the rectifier issue, the one im using is listed in another post on this thread, and has been trouble free since like may, and we use ski nearly every weekend here in fla.
