seadoo@19072
Recently had to rebuild top end of 1994 SeaDoo GTX. Piston seizure. iniatally caused by oil injection hoses to rotary valve intake disinigrated. I have a question as to why the the heat sensor did not sound the buzzer to warn me. Does the epansion of the rings and piston happen so fast that the heat sensor can't react? I tested my heat sensor with a pan of boiling water and a ohm meter, (not digital, gotta use what I got). After the water began boiling, The ohm meter's needle, set at 1K, went to 200K and held there. Is the #278 / 000914 a resitor type sensor or is it a on / off switch? If it is a resistor type, would not the buzzer start off at low volumn and build? I was expecting it to be on / off switch and the buzzer woul activate at full volumn. By the way, the buzzer works. Scared the bejeeses out of me when i tested it. Final question: Does it seem that my heat sensor is OK? THanks for your thoughts.
