Starting problem on 95 GTX SeaDoo from Hades
Texas Guy
Help, I cant figure out what is wrong!! Nothing happens when you depress the starter button, only the click of the button.
Here is what I have so far;
Battery is new
Solonoid is new
Starter switch checks out good with Ohm meter
Cutt off switch checks out good with Ohm meter
When I cross the poles of the solonoid the engine cranks over, so starter is good
What else can I check??? I feel like setting the thing on Fire!!!!
:mad: :mad: :mad:
If you jump the terminals of the solenoid and it turns over, it's most likely the solenoid. I know you said it was new, but you might have a bad one.
Lou
