Last summer, while in the middle of Donner Lake, my son removed the fob to replace it with the learning one. He was unable to re-start the engine. He then reinstalled the regular fob and still was unable to start the engine. Interestingly, the starter motor would only turn over for a second or two and then stop. We took the unit to Thin Air, the Seadoo dealer in Truckee who was unable to replicate the problem.
This morning, the Chief (my wife) and I took the RXP back out on Donner Lake. The engine started up instantly After about 10 minutes, I realized that I had the learning fob installed, so I stopped the engine, installed the regular fob and was unable to re-start the engine. We paddled back to shore, disconnected the battery, and let it sit for 5 minutes, but was still unable to start the engine. The starter moter would run for 4 to 5 seconds, but the engine showed no sign of starting.
When we got back to the house, I disconnected the battery and charged it up. A few hours later, I reinstalled the battery and after a few tries, the engine finally started up. I shut it down, and re-tried starting it and it started instantly every time.
A few hours later, we took the RXP back to Donner Lake, and it started instantly.
When we were done, and near the shore, I stopped the engine and tried re-starting the engine. The starter only ran for a second or two, similar to what happened last summer, and the engine wouldn't start.
At this point, my suspicion is there's something that's temperature sensitive in the electronics that's causing the problem.
Has anyone out there had any similar problems, and if so, what was the root cause?
If at all possible, I would like to fix the problem myself.
Any help or suggestions would be greatly appreciated.
Thanks,
Dick
Thanks,
Dick
