I have read about every thread on here using the search feature looking for answers to my problem.
I thought it was electrical, but maybe not. My problem is like so many listed, so I read two days worth of posts and still don't have my problem fixed.
My problem, clicking noise out of the electrical box. Press the start button, nothing but a slight tick, and then several pops, NONE of which are coming from the starter.
I did replace the solenoid with a new plastic bodied solenoid relay direct from the local Sea Doo repair shop. Replaced, and nothing different. I have swapped the battery (a new one, 3 weeks old) with a new sealed battery. Still no change. I have also arched the solenoid and sparks from the posts, but doesn't turn over the starter. Using an electrical tester, the starter side of the old and new solenoid was weaker.
Made me think the Starter may have gone bad, as I am getting power to the hot (red) wire connection at the starter.
****what I could not find in the previous posts is this: Can a starter that has gone bad or locked make the engine (crankshaft) appear to be seized? I also removed the jet pump and the shaft does not turn. (Did turn clockwise but was removing the shaft end at the end of the jet assembly) Is it possible the starter going bad could make the lower end seem siezed? I am close to taking the ski to the dealer, knowing for a rebuilt starter replacement with labor should be about $350 +/-.
Am I missing something obvious. I am very capable of replacing and rebuilding the starter, but it seems I may be chasing a neverending problem by slowly replacing parts. Solenoid first, then starter, then????
I know the obvious, and so many threads have similar problems, but I just can't nail down the answer as to whether the starter can bind and make the engine feel/seem seized.
Any help, please let me say thank you ahead of time. I have a few more holes in the wall to beat my head against before I go back out in the garage...probably tomorrow.
:banghead:
:banghead:
