First off, I did do a "forum search" for this topic and did get some ideas on where to start, but I just wanted to clarify some things.
I was operating my '99 Challenger 1800 for approximately five hours on this day. It had been shut down and restarted 4-5 times with no issues. Both engines were running great with no "hard starting".
Then during the last start-up and run, I had ran the engine for 15 minutes or so, on plane, at 5,000rpms on each engine. I decided I wanted to pick it up a bit so I took them up to 6,500rpm each. I was running this way for about three minutes when my starboard engine shut down. I tried to restart the engine, but it wouldn't fire.
I proceeded to make my way back to the dock slowly, 5 miles away on one engine. I made several stops and tried to restart my starboard engine, but it just wouldn't fire up.
The engine sounds like it is turning over, but not starting. I haven't pulled the plugs yet, but in order what would you recommend me doing for trouble shooting?
I was thinking; 1. pull plugs/change plugs, 2. check fuel lines/filters, 3. compression?
I don't know where to go after this...any help would be appreciated. My port side engine is running absolutely fine, and I don't believe I am having any battery problems.
