despower
My Sportster is emitting 1 long beep which the manual indicates is a lanyard/DESS problem. However, coupled with the problem is the fact that the throttle seems to only work up to 1/3 way (so I can only get up to 10MPH) at 5000 rpm. I don't know if the beep and limited speed/rpm are related but they did indeed occur at the same time.
The long beep happens continuously (every few minutes) and starts when I first start the motor (i.e. the motor is just warming up) So I don't believe it is an overheating problem as some of the other forum posts have suggested.
The throttle problem is odd because the engine starts up fine and runs fine. I just can't get any more speed past 1/3 throttle. It seems like the fuel feed to the engine just maxes out at 1/3 the way. RPMs never go past 5000 and it doesn't sound like the jet is cavitating.
I took the Sporter out for about an hour today (when I first noticed the beeping and throttle problem). So, I didn't notice any other problems. Had no problem getting to where I was going... it was just slow getting there.
Des
Des
