Phildoo
If you have a Speedster, then you have probably had issues with the windshield cracking at the supports.I tried to be gentle and even super glueing the cracks but no luck, so as I was getting a frosty one out of the cooler, low and behold it snapped off right there on the water.Better than going down the road anyway. This is a bulletproof fix to that problem.
Pic of cracked area
Parts include black 5200, spacers 1", rubber washers,black hinged screw covers and new small stainless bolts
Remove hinge from hull, DISCARD factory bolts.Replace them with new low profile head allen bolts.
Grind off two top rivets, dont waste your time drilling, clean area underneath hinge with alcohol to insure good bond with the 5200.
Place hinge back into original position and drill thru windshield at 90 degrees.
Pic of cracked area
