AusSpeedster
Thanks in advance everyone.
I have been reading lots of posts for weeks trying to troubleshoot but havent managed to solve my issue.
I bought a twin engine speedster (787’s) that had a port engine that would sometimes cut out randomly. It would sometimes start back up, but more often would take 5-15mins of cranking (giving breaks between each try to avoid over heatin the starter) and then would run again for 15-45 mins without a problem.
I rebuilt the carbie because i knew the previous owner had only used it 3 times in 3 years so i thought it may be gummed up, but i found the carbie was immaculate unlike other seadoo jetski carbs i have rebuilt previously.
The problems started after i rebuilt the carbie. The engine no longer starts at all, or even cranks for very long.
I thought i had over worked the starter with all the cranking, so I have replaced it with a new starter. That didnt fix it, still wouldnt crank.
I swapped the starter solenoid from the good engine over. Now it cranks, but not for very long, then after a few tries it wont crank.
I tested the battery, puts out over 350cca, but found the voltage dropped to 7v while cranking, so i replaced it with a new 780cca battery. No voltage drop when cranking but it will only crank for a short time, sometimes wont crank.
I thought it might be a bad earth so i ran an extra 8g earth lead, didnt change anything.
I dont get a beep at all from the DESS but i think thats just the buzzer, ill replace it but it hasnt worked the while time.
I have also ordered 2 starter solenoids just in case its still the solenoids.
Ill also try bridging the starter switch to see if the switch is an issue.
Any other thoughts on what i can check or test? The engine turns very freely by hand with the plugs out.
I have also replaced the rectifier to hopefully solve the random cutting out of the engine that started this whole problem.
