speed & rpm meter stay at zero
petitpied2
Hey there!
I'm new to this forum, I recently bought a speedster, and everything works perfectly fine, exept for all the meter ( is that even the correct word? I'm french...) they just stay at zero, whatever I do...!
What could it be? I changed a fuse (named accessory) and it did nothing)
Thank you!
Max.
The gauges could be frozen up as is very common. Or could be a ground issue, check the ground distribution lug behind the gauge console.
Hey there!
Thank you!
Max.
I don't think the accessory fuse is for the gauges. On my sportster, the gauge fuse is located in the engine compartment in a fuse box near the battery. It is marked "gauges".
I can attest that the grounding block had a lot of loose connections on my boat. Luckily I found this while installing my new audio and battery system and tightened everything up before heavy use. So yes, check the grounding block !
