CamaroMan
so got the SP running yesterday after an insurmountable amount of cranking! The pump in carb looked like it wanted fuel poured down there to prime - dunno but now it starts quite easily.
I noticed the driveshaft bellows spin now and then, is the bearing ceased? do i have to remove the jet to inspect?
Also - on the port (left if facing fwd) is a cluster of tubes and one is alone -
Currently its lying in the bilge - does it need to be plugged in somewhere?
Also the oil tank has what looks like a small plastic solenoid - its open, does it need to be attached to something? (the above hose perhaps?)
Lastly - on top of the engine is a clear tube coming out the top- this was kind of bubbling a little bit of fluid - is this correct? It looks like water but not 100% sure -
thanks!
thanks!
