I found this thing inside the line that sends fuel to the accelerator pump (carb to accel pump). Does that need to be there? Any help will be appreciated.
I read about that in a post earlier on. It is an OEM item and does belong in there. Most never see it and don't put it back when they install new fuel lines.
I'm trying to think but it believe it is there to provide a more stable fuel flow and not pulse the fuel due to the fuel pump.
Just did a search. It does remove the pulsing of the fuel and help with pump pressure. It should be there as if the pump pressure drops you will lose performance as well as likely run lean. Which our engines do not like, c
