Sebastian Bluecrew
Hey again.. I have a Seadoo SP 1997 with 720, Bored .75mm, factory performance pipe spec 1 with ECWI and rev limiter, dual 40mm carbs (142.5 / 75) and a Solas Concord 16/24.. Gets about 41mph bouncing off the rev limiter or cavitating... Serious pull on bottom end and throughout the range. Seems like I need more top end or maybe I have more power then prop?... Stock calls for a 16/35 Aluminum, but my understanding is an aftermarket does not use the same 16/35 numbers? Because nobody makes one of those props with that pitch. What is taller than a Concord 16/24 or should I go with a Skat? I want bottom end and some top end, but I have the power to push it. This set up show no signs or hesitating with this prop. Near wear ring is in there as well as a new carbon seal..
