smoke from rave valve
tangotoronto
good day all
I have notice some white smoke coming from my rave valve, is this normal or anysugestion pls,
I will take it apart to give it a good clean,
aside from maybe its dirty is there anything else to concern about
You'll need to also replace the "O" rings when you clean the rave valves and probably also the gaskets. No sure about the white smoke, have you burned off all the fogging oil?
Lou
They are prolly worn and getting sloppy in the holes and allowing oil to get past and you are seeing it burn off. Thats my guess.
