2001 GTX RFI White Smoke Coming from Throttle Body
DoubleD
Premium Member
Premium Member
Looking for some help with this problem please. I just replaced the crank in this block and now have a no start issue with white smoke coming from the intake when cranking. It doesn't appear that there is excessive oil in the cylinders when I pull the plugs and crank it but there is oil that is pooling up in the air intake housing that attaches to the throttle body. The oil pump appears to be working as intended and is set correctly when I checked with the mirror. I originally thought there might have been too much oil added to the counterbalance shaft during assembly, but figured that would have burned itself out by now. Anyone run into this one before?
