So I've been trying to save cylinders by replacing sleeves.
So far I've done two 787's with success but with slight misalignment.
Yesterday I did two 951 cylinders (two seperate blocks)
Same slight misalignment but learned something.
If I press it back out slightly and use something to turn the sleeve while its moving I can get it perfect and then press it all back together.
With the 787's they were perfect after using this technique on them.
With the 951's I noticed they would set in a little deeper than the removed ones. So going to have to shave the block very slightly but overall I did manage to change sleeves
I wonder what effect this will have. I mean in terms of how well will they make contact and dissipate heat, what happens after they settle in.
Should I have used sleeve retainer...?
Just experimenting and learning on otherwise scrap parts.
