Siphoning Gas
Bob Cook
Hi
I have a 2006 GTX, any suggestions on how to siphon gas?
Looks like there is an anti siphon ”screen” in the gas filler tube, is that right?
Is is possible to siphon through the gas filler tube?
Thanks
I always remove bottom filler neck that is attached to fuel tank while using a battery operated long fuel pump and jack up the front of ski to have all the fuel goes to back of tank and then i winterized the ski.
Why siphon when you can disconnect the fuel line at the fuel rail and activate the fuel pump? Pump it out.
You can do that also, I don't like running the fuel pump low fuel and on bypass, i don't have Can-Doo Pro available, i'm using a 5yr old Battery Powered Kerosene pump its fits perfect at an angle inside the tank.
