This is my normal stance.....
If you break your choke cable, or have some other choke related issue... then install a primmer kit.
Primers are good, and they let the carbs get a little more air to flow... in turn, your engine will make a little more power.  BUT, in something like my boat... (pic in my avatar) the hoses will be so long, that it would take 12 to 15 pumps to get fuel to the engine.  Also, as the engine is running, it will suck the extra fuel out of the hoses.  So... if you have a plug fouling issue, it could make it worse.
FYI... right now, I have 4 water toys, and only my 1990 Si has a primmer. (because I did a carb swap, and the choke was already removed)
