offgrididaho
So arthritis and bad weather be darned, I got it out. The hoist I have for my outboard motor removal made it easy. The purple short straps came from Chinese Harbor Freight.
Whoever pulled the motor last made numerous mistakes.
Tailcone muffler bolt not installed
1 carb bolt loose and falling out (it only has 2)
Both rave valves leaking black trails down motor at gasket or valve.
NO O-rings on head stud bolts.
No clamp on shaft to pto black rubber grease cup/cover.
Airbox laying in bottom of hull.
Leaking 3/32 oil line.
No clamp large intake oil line
Other bolts not tight here and there.
Question:
Where can I get the tool to get the mag off? Anyone have a part number?
I ordered the special hoses for the oil lines.
What type of lines for fuel water?
Where to buy carb rebuild kits?
Where to buy upper rebuild kit and lower gasket kit?
Which pistons do I want for the 951-carb 2000 year model?
Do I have the cases aluminum blasted?
What paint is best for the cases? I would like to use a blue metal-flake clear or silver speckled.
Any other suggestions?
Question:
