Shes out.. +Tear Down and some questions.
So arthritis and bad weather be darned, I got it out. The hoist I have for my outboard motor removal made it easy. The purple short straps came from Chinese Harbor Freight.
Whoever pulled the motor last made numerous mistakes.
Tailcone muffler bolt not installed
1 carb bolt loose and falling out (it only has 2)
Both rave valves leaking black trails down motor at gasket or valve.
NO O-rings on head stud bolts.
No clamp on shaft to pto black rubber grease cup/cover.
Airbox laying in bottom of hull.
Leaking 3/32 oil line.
No clamp large intake oil line
Other bolts not tight here and there.
Question:
Where can I get the tool to get the mag off? Anyone have a part number?
I ordered the special hoses for the oil lines.
What type of lines for fuel water?
Where to buy carb rebuild kits?
Where to buy upper rebuild kit and lower gasket kit?
Which pistons do I want for the 951-carb 2000 year model?
Do I have the cases aluminum blasted?
What paint is best for the cases? I would like to use a blue metal-flake clear or silver speckled.
Any other suggestions?
Sea-Doo flywheel, puller… Amazon, eBay
Carb kits should only be Genuine Mikuni.
Be sure to read, Mikidymac’s carburetor rebuild, sticky at the front of the two-stroke section.
A 951 with 200 to 250+ hours is going to need a crank shaft / balance shaft rebuild… seals..etc
In addition to your new pistons and fresh bore, so on and so on.
Wise guy on here says “ do it once do it right !”
Yeah I have a place to do the crank. I have never seen anyone talk about doing the balance shaft. Even the crank shop didnt ask me about it when I talked to him. I will ask again. So for the mag puller where do I get that tool that threads on the end? The pto is easy with a flywheel puller but the mag is a special tool. I also need a blind hole puller for the starter bearing. I am going to have the cases blasted so I need to replace that starter bearing, bendex and should I also replace the starter or rebuild it?
Rebuild your OEM starter. Replace the brushes, clean the Commutator and lube.
Aftermarket Chinese starters are junk.
eBay and Amazon will have rebuild kits
Rodger that.... Crank shop said to send in balance shaft as well. He said same thing about starter you did. Manual say to use loctite 518 for crankshaft case split reassembly. Do you also replace the bendex or rebuild? What about the bendex bearing in the case? Replace that?
Can I get the cases aluminum powder blasted to take off old paint or skip it? So many tiny little details that have to be exactly correct!
Crankcase half’s ..reassembled with Yamabond
Don’t know if bendix is ‘rebuild able’ was it ok before?
Needle bearing in case needs protection when blasting cases…
"Negative Ghost Rider the pattern is full"
This is from the service manual.
Crankcase
Crankcase halves are factory matched and there-
fore, are not interchangeable or available as single
halves.
947 Carburetor-Equipped Engines
Prior to joining crankcase halves, apply a light coat
of Loctite 518 on mating surfaces
. Do not apply in
excess as it will spread out inside crankcase.
NOTE: On aluminum material it is recommended
to use Loctite Primer N to reduce curing time and
increase gap filling capability. Refer to manufactur-
er’s instructions.
Crankcase
halves.
. Do not apply in
er’s instructions.
Stick with Yamabond or equivalent. Don’t use 518 as specified in the manual.
Do I have to worry about drying time while applying to surfaces and clogging up anything inside if it squishes out?
AI said use Y4 or 518 on machined to match surfaces. What did Seadoo use originally back in 2000?
From AI
518 or yamaha bond 2000 gtx engine case split surface manual say use 518 rebuilders say use yamaha bond
For a 2000 Yamaha GTX engine (947/951 Rotax) or a similar 2000-era Yamaha engine, you can use either
Loctite 518
or
Yamabond 4
(specifically
Yamabond 4, not 5), as both are designed for rigid, machined aluminum flanges without a gasket
The choice often comes down to personal preference or specific assembly needs:
Loctite 518 (Anaerobic Gasket Maker)
  • Best for Aluminum: Loctite specifically recommends
    518
    for aluminum flanges.
  • Cure Type: It only cures in the absence of air (anaerobic).
  • Safety Advantage: Any excess that "squeezes" into the engine interior stays liquid and dissolves harmlessly into the oil, preventing clogged oil passages.
  • Ease of Disassembly: It creates a bond similar to "weak glue," making future case splitting easier than some silicone-based sealants.
Yamabond 4
(Semi-Drying Liquid Gasket)
  • Manufacturer Standard: Many Yamaha service manuals and professional rebuilders specify
    Yamabond #4
    because it is what the engine was originally designed with.
  • Pliability: It remains semi-pliable and flexible when cured, allowing it to better handle engine vibration and minor thermal expansion.
  • Proven Reliability: It is a staple in motorcycle and PWC engine building for its excellent adhesion and fuel resistance.
Which Should You Use?
  • Use
    Loctite 518
    if you are worried about excess sealant clogging your oil passages or if your manual specifically calls for an "anaerobic" sealant.
  • Use
    Yamabond 4
    if you want to follow the rebuilder's standard and prefer a sealant that stays flexible to handle high-vibration environments.
Crucial Note: Ensure surfaces are spotlessly clean (use acetone or alcohol) and apply a very thin, even layer. Never use standard "RTV" silicone (like red or black) for case halves, as it can be too thick and alter critical bearing tolerances.
Would you like the specific torque sequence for those engine case bolts to ensure a proper seal?
Use 518, it's in the Seadoo manual. That's what came with it from the factory.
I asked AI about that. My local engine builder here uses ThreeBond 1211.
For the 2000 Sea-Doo GTX (featuring the Rotax 947/951 engine), the original factory service manual originally specified
Loctite 518
as the anaerobic gasket maker for the crankcase halves.
YouTube +1
However, Sea-Doo/BRP later updated their recommendations, and many professional rebuilders shifted to alternative sealants due to better performance in high-vibration marine environments:
Factory & Professional Evolution
  • Original OEM Spec (Late 90s/2000):
    Loctite 518
    was the standard anaerobic sealant used on the machined aluminum flanges of these Rotax engines.
  • Updated OEM Spec: Over time, BRP/Sea-Doo transitioned to recommending
    Loctite 5910
    (a high-performance RTV silicone) for these cases, as it offers better tolerance for micro-movements and vibration.
  • Rebuilder's Favorite: Many specialists prefer
    ThreeBond 1211
    or
    Yamabond 4
    . These are semi-drying liquid gaskets that remain slightly flexible, providing a more resilient seal against the "case flex" common in the 951 engines.
    Facebook +3
Application Standards
Regardless of which sealant you choose, the method is critical for this specific engine:
  • Surface Preparation: Surfaces must be perfectly clean. Use a solvent like acetone or lacquer thinner to remove all traces of oil before application.
  • "Dab" Method: Apply a very thin, translucent layer. Rebuilders recommend using a finger to dab and smear the sealant so it is nearly see-through.
  • Avoid Excess: Excessive sealant (especially RTV) can squeeze into the crankcase, potentially blocking oil passages or interfering with bearing "crush" tolerances.
    YouTube +4
I then asked AI what is the current sealant used.
what is the current sealant in the 2025 seadoo crankcase halves
For
2025 Sea-Doo models, the current factory-recommended sealant for crankcase halves and similar engine assemblies is
Loctite 5910
Sea-Doo® Official Store +1
While earlier 2-stroke engines like your 2000 GTX originally used the anaerobic
Loctite 518
, BRP has transitioned to
Loctite 5910
for modern Rotax engines because it is an RTV silicone that offers superior flexibility and better resistance to joint movement and high vibration.
Engineered & Industrial Solutions | EIS +1
Why the Switch for 2025?
  • Vibration Tolerance: Modern 4-stroke Rotax engines (like the 1630 ACE) face different thermal and vibration stresses than older 2-strokes.
    Loctite 5910
    is designed specifically for flexible flanges and machined surfaces that experience micro-movements.
  • Gap Filling: It is effective for gaps up to 1 mm, whereas anaerobic sealants like
    518
    are best suited for perfectly flat, rigid flanges with almost zero clearance.
  • Oil Resistance: It provides excellent resistance to the synthetic oils used in high-performance marine engines.
    next.henkel-adhesives.com +2
Buying & Alternatives
Application Warning
If you are using this on a rebuild, remember that modern RTV-style sealants (like
5910
) must be applied in a very thin bead. Unlike the older 518, any excess
5910
that "squeezes" into the engine will cure into solid rubber bits that can clog oil spray nozzles or pick-up screens.
Would you like the official BRP torque specs for the 2025 Rotax 1630 ACE crankcase bolts to compare with your 2000 model?
Just ask AI how to rebuild a 951 but don't post the response here.
For the sealants its nice to see what the summary is. I have the manual for rebuilding the engine. Seadoo changed sealants so the AI explains it.
Maybe someone wants to know which to use like I did and why. Now they know. Thats what this forum is for.
Use the Yamabond 4. Do not use the 518.
The search function covers this. Micidymac sums it up pretty well:
Even Seadoo quit using the 518 back in the day. If you read the specs, 518 isn’t gasoline resistant. There’s obviously fuel & oil inside the crankcase of a 2-stroke engine. Every other manufacturer, engine builder and even Seadoo now uses the same product under different names, MotoSeal, HondaBond, YamaBond, KawChem and ThreeBond 1184
Checked the search first.
Ill use the yama4 like you said.
Easy search results​
Return to search
Select: Thread title
Keywords: do i use 518 on crankcase halves
Posted by:
Search forums: All forums
No results found.
Tear Down--->
A few questions. Its been a long time since I have torn down an engine.
I measured the ring gap at top and bottom of both cyls. I got .030 at the bottom and .060 at the top. I measured the piston clearance at top of cyl and top of piston at .020. Upside down with skirt pointing up I get .005 both cyls. Bottom of cyl at skirt .005. Measured cyl ID at 88mm. Measured piston OD at 87.9mm. These measurements are done with a pair of Harbor Freight calipers and feeler gauges.
Can someone look at the piston (rear) and cylinder. One is scuffed with vertical lines that are deep and the cylinder is scoured deep too. You can feel it with your finger.
Top of cylinders both have a prominent ridge at the end of the piston vertical movement up. Assuming this is normal wear. Base gasket has a small bead of some orange sealant???
All head O-rings, except for one were down inside the stud hole and not at the top of the head.
Pistons are WSM with caged needle bearings, they were pointing the right way.
The scoured piston and cyl had both rings upside down with letters on bottom.
Scoured cyl also had one bolt loose on carb.
Base gasket has 8 holes in it, assuming that means some thickness specs.
So the boring can be done in .25mm increments from .25-1mm?
Does that blow-by on pistons look normal for aprox 10hrs after a first rebuild?
The pics..........
Return to search
Posted by:
No results found.
Tear Down--->
The pics..........
View attachment 69310View attachment 69311View attachment 69312View attachment 69313View attachment 69314View attachment 69315View attachment 69316View attachment 69317View attachment 69318View attachment 69319
What where the questions
See them now, never seen 8 holes before but yes it indicates thickness, 6 mil was thickest I’d ever heard of, 8 holes should be 8mm.
Yes, oversized pistons come in .25mm increments
Does the piston with the 3 vertical scars look like it hit a port, a rave valve or something else?
Also both crank end seals were worn out on the ID. I could spin them on the crank freely.
On the cases, should I just clean and de-grease myself or have them blasted? I don't really want to pay extra $$ cash and have to paint everything.
Whoever did the top end sure was a bonehead, so many mistakes. They also glued the base gasket to the case. UGH!!!!
How do I get the mineral deposits out of the one spot in the water passage? Near top/right head stud in water passage.
I am so far from qualified to answer your questions it’s not even funny so hopefully someone else will chime in. I was looking at your other thread and my best guess as per the the vertical grooves would be that it ran lean possibly burning off the oil film allowing metal on metal, maybe the excessive heat due to running lean also expanded the piston enough that it was running with to tight of clearances between piston and cylinder wall. I’m really just a monkey turning a wrench and not that experienced at that. Anything I do, I just try and make it all right, by using the right parts, taking measurements, doing a leak down test on the engine after work to ensure it’s not sucking air, I use the right oil since it withstands higher temps. Hopefully someone can tell you the cause of those vertical grooves for sure
