Water sports
Question 1- Buzzer, can this be tested by placing a positive and negative wire from the battery to see if this sounds.
Question 2- This unit under the boat on the underside of the hull what is this, here is another photo showing from the inside under the floor, see photos attached,
Question 3- Was replacing the pipes on the exhaust and the brass fitting looks to be blocked, should this be fully open, see photo attached.
Question 4- Hawk eye, could you please tell me what this is actually used for.
