I have a 1995 Seadoo Speedster and am in the process of replacing the seal carrier bearing. Have a few questions:
1. When I was removing the drive shaft the ventura (pump) came off of the spindled end. Is there any special precautions besides greasing it before I insert it back into the pump?
2. What type of sealant should I use between the nozzle and the ventura? It looks to be a red sealant that was there previously?
3. What type of sealant should I use around the ventura before mounting it back onto the hull? They used a flexible black gasket sealant before? What is the name and where can I purchase it?
Thank you.
John
Thank you.
John
