Seadoo XP Jet Pump Oil
kyleabrams
Wondering if I should change the pump oil or not...it's a 95 seadoo XP. I just found out the shop did not change it when they went through it. I bought it about a month ago and the previous owner said that it sat for 3 years and has not been changed for a while. It's been fine right now, apart from a rattle at idle from the jet pump. I've put probably 10-15 hours on it so far. Should I change it or can it wait until winterization? (probably a few weeks left of riding)
Thanks in advance!
It's a quick thing to change if you decide to do it now.
The Jet Pump oil change;
If you look into the nozzle in the rear of the ski you will see a cone with 3 screws and an oil filler allen screw.
To change it,
1) Take off 4 13 MM bolts holding nozzle and 10 MM bolt holding steering.
2) Get something to catch the old oil in, drain pan or margarine cup etc.... (don’t forget the nose plugs, the oil stinks to high heaven)
3) Remove the 3 8 mm bolts holding the cone on.
4) Pull the cone and drain the oil out. Prop the front of the trailer up as high as you can to get most of it out.
5) Inspect the rubber “o” ring and if it is good apply silicon and reinstall the cone. Make sure the allen fill plug is on top.
6) Lower the front of the ski and add oil** to the cone. When it is full, take a brake and have a drink. There is air in the cone and when you go back you will see that it is low. Top it off and take another brake... do this until the fluid does not lower again. I often start the ski for a few seconds to make sure oil is all the way worked into the bearings and all the air is out.
7) Wipe silicon on the set screw and screw it in (be sure not to run it all the way into the cone. just deeper than flush is fine. Let it sit 24 hours to cure the silicon and put the nozzle back on.
**NOTE: Use Sea Doo 75w90 GL5 Synthetic Polyester Oil, or similar same wt.
Karl
Sounds easy enough...for silicone, would the red atv stuff work? or is something preferred?
I think I might hold off a few weeks on the change. If it's been fine for the time I've ran it..it shouldn't hurt anything. (hopefully) :)
Be sure it is silicone so it won't break down in the water. If water gets in it is a silent killer of bearings, because you won't know they went bad till you have problems.
Karl
