marcxp95
Hi guys! I don't use to post here because I am spanish and is hard to me to speak in english.. :facepalm: , but now i'm desesperate and I hope you can help me . I have a seadoo 1995 xp ( 717 engine dual carb.) And it doesnt work good.. Every time I put the seadoo in the water It goes very bad in low rpm from 1000 to 3000 rpm. When it came over 3000rpm it runs perfect but when i drop the throttle when de engine has to start from low rpm's again , the same problem every time.. And when I turn of the engine some times is hard to start again the seadoo.
I put here som information useful..
-Mikuni rebuild kit new
-All the gaskets of the engine new
-compression in both cylinders a bit less than 15
-Low speed 1-3/4 high speed 1/8
-I revised that the rotary valve is in the correct position
-Looked for leakage of water from the cylinders to inside the engine.
2 Rounds of cold beer to who finds the problem or give me some useful information... :cheers: :bigear:
