Seadoo Low-end bogging ?
Owenar11
So I just bought a 94 xp 657x and it has a low end blogging problem. The guy before me told me that he just swapped the plugs off an old ski but they looked fairly good. I replaced them today, but I haven’t taken it back out yet.I also did a genuine Mikuni rebuild for the carbs. I synced both of them perfectly. After I put in new spark plugs today it started right up fine. I just want to know if this is the problem or if it’s something bigger. Any help would be greatly appreciated.
What's your compression at?
No I don’t think it does
Typically when you have plenty of power on the trailer but bogging in the water or loss of power on the water it means the top end needs to be rebuilt, especially if the carbs have been rebuilt and tuned properly
Do you still have the grey tempo fuel lines? Those are always bad and can starve the ski of fuel, it's always a good start to replace those as they are much cheaper and easier than a top end rebuild
Its low. The engine is tired. You may be able to revive it with a hone and fresh set of rings. reving it on the trail will tell you nothing since there isn't a load on the system.
No I don’t have the grey tempo lines, they are all new black fuel lines and thank you I will look into getting a top end rebuild. I really appreciate the help everyone
