Seadoo HX Carb problem
So I’ve been having issues with my HX, got everything fixed, but final problem appears to be, gas doesn’t get into the carbs, so it turns over just fine but doesn’t start. I’ve rebuilt the carbs, changed out the gas lines, so puzzled by what the issue could be. I did notice that one of previous owners did swap the choke for prime, but it looks hecka sketchy. Does anyone have good detailed pictures of how fuel lines and choke is connected to carb and to engine on the seadoo hx ? I want to try to redo everything to “ factory “ settings, hopefully that helps. Thanks!
So are you reinstalling the choke system?
Did you use Genuine Mikuni parts and correct springs?
Follow the carb rebuild sticky?
Replace the fuel selector and strainer o-ring?
i noticed the issue with fuel getting to crab but not from carb into cylinders, and I’ve installed a one way hand primer pump right by carb to see if I can physically pump some gas in there, and I couldn’t do it
Get rid of the inline primer.
You have something wrong with the carbs if you can't pass fuel.
