Seadoo GTX 1997
angel_1983
i just buy a seadoo GTX 1997 i change the fuel lines, new carbs, new battery...
im thinking on go premix or lived oil injected???? i need help im new on this the engine is 787 and the compresion is 172 on each one
Hi and welcome to the forum. You'll find a lot of good people here with a lot of good information.
My advise is to stay with oil injection, its reliable, much more efficient, and cheaper to use than premix. Your compression is way high, a factory fresh engine is 150. Was your engine just overhauled or have the top end redone? I would check it again with a known calibrated compression gauge. If it's still high you probably have a problem with the squish area.
Check the compression and repost.
Lou
