SEA DOO Gti Limited 155 - problem
lucenaf
Hi guys,
I just bought a used SEA DOO 155 Gti LTD 2012 49 hrs.
It was parked in a garage for 6 months.
When i tryed to used it was working only 2 cilinders, i ask for mechanics and
they said that would be the spark plug or nozzle injector.
The problem is that they dont recomend to clean de injector, they want to change.
Is that correct? Because im my country (brazil) is expensive ( u$400,00 ) the nozzle.
More info is needed.
Do a compression test, lets make sure the engine is not the issue.
Do a spark test?
Let us know what you find and we will go from there.
These 4 tec motors are notorious for eating plugs. They are cheap so throw in a new set of plugs. If that doesn't fix it then it's time to look at compression. Injectors rarely fail.
