Ccarlson142
I just purchased a sweet 2018 Seadoo GTI 155 Limited with 122 Hrs. The owner just had its 12 month service done (oil, plugs, etc) at a large Seadoo Dealership in Georgia.
The previous owner gave me the invoice for the work. On the invoice, they recommended a Shaft - Impeller, Angled Bearing and everything else to replace these 2 items. There are no notes on the invoice saying if they need to be replaced or not. I assume that this is based on hours/age? There is no mention of replacing the wear ring and the impeller itself. I called the dealership and he said that they would have recommended a wear ring if it was needed. I looked the the impeller with flash light and the ring looks great. However, the impeller and exterior shaft have a bit of rust on them. It was not a salt water machine (to my knowledge). There is no indication of any other rust/oxidation on the machine and I purchased it near Atlanta Ga.
So.. here are my questions:
1. Do I need to replace the Shaft - Impeller and associated parts? Is there a way to check the condition of these part?
2. Do I need to be concerned with rust on the exterior shaft?
3. Do I need to be concerned with rust on the impeller?
I will be only running it in a fresh water lake.
Thank you for any advice you may lend.
