Luc Dorais
Hi, Have 1999 RFX gti that idles and has good throttle response while I use the flush line to run and will idle all day at around 1500 to 1600 rpm if i let it, with no issues, but when in the water, if I am moving there is no issue but it will bog down and run rough, backfiring if I idle thru a no wake area for more than 5 min, then when I stop and look at plug front cylinder plug is wet? I replaced the plugs, gapped at about .024 again it will run like a banshi all day but if I idle for an extended period of time same thing happens. It sat for about 2 years and I have put in another hour of run time since, fresh gas and oil no help only has 105 hours. Trying to figure out what to do next? Thanks for any suggestion. Luc
