Does it crank but not start? or does nothing happen when you hit the start button. Based on your statement above it sounds like the battery is dead. Check the battery voltage with a multimeter before you put your key on it, then check as you put your key on it. If not 12 volts or above I am willing to bet that is your issue. This all leads to is it an old battery? You can also take the battery out and take it to a local auto parts store and have them load test the battery to see if it is good or needs to be replaced. Most auto parts store sells the batteries for the ski.
The battery voltage is good(fully charged on smart charger) If you put the key in, the display comes on but then disappears. It does not go through the check cycle and when you press the start button , nothing happens.
I have the same issue on my 2011 GTX 260 limited I changed the solenoid, relay, battery now I’m checking for corrosion I’m highly upset can’t figure out what’s going on. The gauges light up then dies.
