Rxp 215 stopped while riding, now will crank but wont start
Scoden
Hey guys,
Yesterday was out riding to the islands and all was fine no missing, wasnt down on power. Cruising at aabout 70 when the ski missed twice than stopped. At first i was poretty certain my fuel pump went. But using the diagnosic cap fuel comes out. I than pulled all fuses and tgey are all fine. Remember its cranking but not starting. Havent had time to check anything else (most things checked on the water), It seems that all things are plugged in. Is there any sensors that could cause no fire through all cylinders i should check? Or any advise of where i can look for clues.... thanks guys
So a spark test. If you have spark then you may have an internal failure such as a chain. Until you test the basics there really isn't much sense in guessing,,,
Ok so one coil has a damaged shaft but reads the same resistance as the others..
One spark plug has had a major failure and blew out the element into the cylinder..
So looks like im pulling engine out to have a look. AGAIN
