Richieskis
I had bolt drop down carb, damage rotary valve, I already had spire bottom end halves and rotary valve and what I thought was spire cover only to find out my spire must be for a duel carb set up I have single set up 97 GTI here is a picture of my original cover, hope you can see the damage, is that to much or is it still useable ? One more question should the mating surface with the rotary valve be smooth from edge to edge or should there be a slight lip on the very edge of the valve mating surface, thanks in advance for your help
