Hello All! Great forum and community. This is my first post but I have read tons of information. I need some advice on my 2000 GTX RFI 787 motor. I just picked this thing up from somebody who didn't want to fix it. It has a new battery and turns over fine. So, I went through the process and found that plugs are new and have spark, fuel pressure is good, etc...
Upon digging, I found that the rotary valve was not turning. So, I tore it apart and pulled the shaft and found as suspected, the brass gear was shredded down on one half.
I know, I know, I read so many conflicting posts. Some say with the brass in there, I have to pull the motor and rebuild the lower half. Others have said it is just brass and being a soft metal and sealed away from the cylinder/connecting rods, just clean it out best you can and go for it. I know that it would probably be best to tear it apart but I want this one to be a quick and dirty fix for now. I have a small hose attached to my shop vac and was able to feed it all around and suck up as much as I could. I then poured some oil in there, turned it over and sucked the oil back out as a way to "rinse" it out. This is good for now.
So, then, I bought a whole new shaft which came with gear, seal, bearing, etc... and pressed it in. A new rotary valve plate to go along with it too. Did the timing and put it all together. She fired right up after. Several times of shutting down and firing up, every time, perfect. The next day, I decided to run water through to run it longer. I started her up and turned on the water. She was smoking really bad at first, assumed it was due to all of the work I had done. Ran at idle for about 5 minutes and was running strong. Did some revs, no problem. Towards the end of the 5 minutes, I went to rev and it sounded great but then it started bogging down and died. Went through some things and ultimately found, my new rotary shaft brass gear shredded again, even worse than the original. All the way around instead of half flat.
I researched some more and read that the gear on the crank could be off center but it doesn't appear to be. Seems to be centered right in the hole. Also, the condition of that gear looks perfect. No bent or missing teeth. Also, cranked while looking in the hole and the crankshaft doesn't appear to bent or wobbling at all. So, now I am left with some questions. Why did it fail the first time? More importantly, why did it run for a while for me with a brand new part and then fail again? What could cause this besides the things I already listed which seem to check out?
I will tell you what I suspect. Could the oiling system not working right cause this? I see the two small lines that go from the pump into each port. These must be to do the premix for the fuel? Then there is a large line below this center rotary shaft chamber. I assume this is to oil that chamber? I will tell you, it seemed rather dry in that chamber when I pulled the new shaft back out. The rotary valve itself had oil on it but not much inside of the chamber.
Another theory. Is it possible that I didn't get seated in the rear bearing inside of the engine? I must admit, when I pulled the first/original shaft, I didn't pay any attention to that rear bearing and just jammed the new rotary shaft in there. I assumed it would all line up but what if that bearing had slipped out of the seat when I pulled the first shaft and therefore, the new one was just floating around back in there?
Sorry for the long story, wanted to paint the picture. I can check the oiling system and be extra careful when I re-install with regard to that rear bearing but wanted to get thoughts from all of you. I don't want to put yet another one in and shred it too. Just another side note. The motor has low hours and looks to be in really good shape. Compression in both cylinders is 145 and 150. So, I hate to tear it apart if I don't have to.
Thanks!!!
Mike
Thanks!!!
Mike
