RFI diagnosis
Shaw520
2001 GTX RFI 787. Machine has been sitting with no battery for over a yr. I do NOT have a candoo pro;
Fresh battery installed,.. jump solenoid and engine turns over fine.
Attach DESS and nothing happens, press start/stop button and info center comes to life, shows clock, compass, fuel guage, all working normally. Press start button no starter engagement,... press start button three more times and get a chirp and a beep.
Any Help ??
Sounds like the MPEM isn't recognising the key. Have you got any other keys? It could also be the post.
Yea, thinking you're right,... I cleaned the post and key good,.. next step is to try and contact PO to see if theres another key for this beast.
All fuses in elec box and MPEM are good,... all still have their original factory grease !
Yep, not reading key at all seems like (suspecting lanyard post internal magnetic switch contacts) if it reads the wrong key should be a long beep, right?
Right !,... cause when I put the key on, no beeps, no info center, nothing,....
if I press the start button info center comes alive with correct readings,.. push 3-4 times more I get a chirp followed by one beep,... info center stays on for the 33 seconds then goes off as it should.
Is there a test I can do to it ??....w/ dig volt meter in hand...
Here ya go,,,
DESS TESTING
The Mpem, (Multi Purpose Electronic Module) needs to beep 2 times to let you know it is ready to start. Clean the post and cap with soapy water. Don't use any grease of lubricant on it as it needs a clean connection to make contact. Connect the lanyard to see if it is making a connection. 2 beeps and it's ready to fire up.
Engine start/stop switch verification;
Disconnect the Yellow/Red wire of the start/stop switch. Using an ohmmeter, connect test probes to the Yellow/Red wire and to ground. Measure resistance, it must be an open circuit (switch is normally open). Depress and hold switch, the ohmmeter should read close to “0” ohm.
Safety Lanyard Switch Verification;
If 2 short beeps are not heard when installing the safety lanyard, disconnect the switch wires.
Safety lanyard removed;
connect the test probes to switch Black and Black/Yellow wires. It’s an open circuit, there should be no continuity.
Connect one test probe to the White/Gray wire and the other test probe to the switch terminal. Measure resistance, it should be “0” ohm. Connect one test probe to the Black wire and the other test probe to the switch ring. Measure resistance, it must be close to “0” ohm.
Safety lanyard on switch; connect the probes to switch Black and Black /Yellow wires. Measure resistance, it must be “0” ohm.
Timer Verification;
The timer is integrated into the MPEM. Always confirm that the fuses are in good condition. To confirm operation of timer, remove the safety lanyard from switch. After 5 seconds delay, depress start/stop button once. The timer should stay on for 33 seconds (for example, the gauge(s) will be activated) and than turn off.
DESS codes. It is possiable that you are getting a mixed code.
DESS Codes/ Beeps
2 Short beeps …the engine is ready to start
1 Long beep …no communication to MPEM
4 Short beeps… (on Jet Boats) Shifter is in gear
8 Short beeps…defective MPEM
1 Continual beep…engine over heating
Advanced Self- Diagnostic Mode
By pushing the start/stop button 5 times, you’re putting the DESS in advanced diagnostics. When you have successfully done this, you'll hear 1 short, 1 long beep then, put on the lanyard cap. The engines should start if everything is ok.
2 Short beeps means MPEM can’t read the lanyard cap or it has bad magnet. It could be a bad wire connection at the Lanyard switch.
2 Long beeps means wrong lanyard or bad connection of DESS connection
3 beeps signal the wiring harness of the DESS switch are grounded, or a short circuit somewhere.
You may have a bad connection in your wiring harness, from corrosion. Go through your electrical systems connectors and check for corrosion. Clean them with some contact cleaner, then die-electric grease.
To listen to the codes again start from the beginning.
PO was kind enough to get back to me, but unfortunately NO extra keys,... Ill be doing the diagnostic test provided above by Coastiejoe when I get home.
Success !
https://www.youtube.com/watch?v=9BKQYReOnGA
There was an issue with the DESS post, when I first tried the test above I wasnt getting continuity from black to black/yellow with key attached. I played with it, tapped the post thinking maybe the magnet was stuck, and after a couple of attempts I then had a connection. Plugged the connectors back together, attached key and got the sweet sound of 2 beeps !,... hit the button and she fired right off! woohooo!
