I have a 96 gsx with 787 motor. With a fully charge battery i will run about 20 min. Then just die. will restart after setting go 100 yards and die
All low voltage related. I have checked the stator for out put and ground. Has fine ac voltage. Checked all wiring from Rectifier to stater. All fine. It is a 3 coil stator going to Rectifier.. While running with a hose I pulled the red feed off the Rectifier
The side that plugs into the Rectifier has battery voltage 13+ positive DC The side coming from the rec. varies according to RPM but it reads negative DC! I am using a very good multimeter. I have checked with several dealers and none have heard of this. I had a friend that works on boats check it also to see if I was doing something wrong.
He said he had a Mercury outboard do this once but could not remember what caused it. I don't want to just start throwing parts at it. PLEASE HELP
Also all fuses are fine.
Thanks Ron in Arkansas
