reserve
The Valve can be removed & cleaned (wired out). Pik the cap and remove the #2
phillips screw, use a 30mm socket and remove the plastic nut. TAP the valve into
the hull and open front hatch, remove basket, its there. Mark each of the three lines
and nipples with a color marker, then cut the band and pull line off the valve. Bills86e
