Removing oil stains from hydroturf
dsw222
While i was doing my top end kit / carbs / rave valves, i managed to get a few spots of dirty oil or marine grease on my purple hydroturf. I tried briefly to remove it with Dawn dish soap and water, but that didn't work... and i was so frustrated with my boat not working that i said "screw it" until i could get the boat fixed
Well the boat is working now, and i'm kicking myself for messing up my nice hydroturf
Any ideas for something that would take out dirty oil / grease spots? Or am i stuck with it?
(I dont want to experiment with products until i get your opinions... i dont want to do more damage than i already did)
Thanks guys!
Castrol Super clean.
It will work... but it will strip any wax it comes in contact with. Also... if you walk away from it, and let it dry, it may damage the hydro turf. (but I use it all the time)
Try to just soak the spot... give it a minute, then scrub it with a tooth brush, and rise it with water. It should lift out the stain.
Yep. Super clean is the bomb. I stained my turf with black grity stuff from working on the trailer and it got it off easy.
