citationSS
Hi all,
I have been searching for hours to find the ohm test on a regulator/rectifier for a 94 SPX with a 657 engine. I found the test for the 757 which has 3 yellow wires, but can't find anything for the older 2 wire regulator (yellow, and yellow w/ black).
Background on this project:
New battery.
Not charging - Voltage test shows no change as rpm increases (just reads battery voltage)
Charge coil ohm test is between .05-.06 ohms as the manual states.
Now I would like to test the regulator before dropping $70 on a new one.
Thanks,
Keith
New battery.
Thanks,
Keith
