Rebuilt GSX Ltd - no spark
Still Onething, Are You sure this "holder" is the right way? ( probably it is) it is just something to hold cables in place, but if it can "interfare" or something to the CPS if it is assembled wrong, or pinch a cable?
Probably not, but anyway, check it!
Also brush/file on the soldier joint on pickup coil and measure there, and then also at the connector at magneto cover, also as a last step measure on the connector at MPEM... to be sure there is good wires all the way to Mpem
At this point I would put a meter on the 3 yellow wires coming from the mag coil while cranking the engine.. You won't get the full AC reading but you should see something.
