BMANN06
Hey All,
Any help is super appreciated! I have a sportster 4Tec (155), every time I start up the engine I get the following codes P0264 and P0267 which is injector short to ground or open. I only get one occurance of each code at startup (as seen on candoo scanner), engine runs just fine after that and no more occurances while running but get dash light and would like it to go away. Here is what I have done
-This engine is freshly rebuilt, maybe 45 minutes on it so far.
-I have 12ohms across each injector
-I have swapped all three injectors with known good
I've confirmed a good ground on PIN #1 of each injector. I'm a little confused by the seadoo manual about this statement "Check for 11.4 to 12.6 ohms between engine connector pin 3 and ECM connector pin 14. Where is pin 3 of engine connector?? If its the ECM connector I don't have any conductors in PINS 2,3,4
This boat is sold and the guy is picking it up Saturday if I can get this sorted that would be awesome!
Thanks a ton!
Thanks a ton!
