Hi, relatively new to site. New to PWC.... Check out a SeaDoo today. Its a 2001 SeaDoo GTX 125hrs. Its in Canada, it's been sitting in a garage for approx. 3-4 months winterized. Unable to test in water but i did check compression (engine cold).
I had a reading of 120psi in one cylinder & 121psi in another (check 3 times with throttle wide open). I was under the impression it should be up to 135 psi. Is this a sign of trouble or just the fact that the engine is
1. cold
2.battery may not be fully charge.
3. its winterized.
4. sitting for 4 months.
5. This is normal & since the psi are the same just normal wear.
Looking to buy any insight would be appreciated. Thanks in advance
1. cold
3. its winterized.
