Rave Valve installation
mramccm
Does anyone have data on Rave Vale installation. All I can find says to tighten the piston down finger tight, make sure the valve moves in the housing freely.
Nothing on degree of movement. etc.
. :confused:
Chuck in MO
the shop manual lays it out clearly... did you look in there? its in the "top end" of the engine part
yea pretty straight foreward...the top should be labled "top" and if you can give them a lil pump by hand there all good, as long as you feel no "sticky" resistance from oil build up it should be ok
Thanks guys & gals found some pretty good advice on the forum. My Clymer manual leave a lot to be desired as far as detail.
Chuck
