Radio shack beeper
Seadoobuddy
Premium Member
Premium Member
OK, I've been told to buy a new beeper since mine works only when it wants to.
I've seen threads with the model number for it but I can't find them. :banghead:
Dr Honda or ???? what do I buy? :auto:
these are the exact replacement will fit right back into the same bracket it came out of just cut the wires and use waterproof butt conectors that you can get from lowes just crimp and heat they shrink to make it waterproof easy as 1,2,3 good luck
The radio shack part number is: 273-068.
I've installed that buzzer into at least 20 skis over the years... and it works great. It will directly replace a buzzer in the boats... and with the skis... it's just a little fatter, and all you have to do is trim some of the foam in the handlebar pad to make it fit. But, for $9... it works well. (OEM is about $70)
Cut your old buzzer loose, and solder the wires to the positive, and CONSNT terminals on the Buzzer. In the pic below, it's hooked to the "PULSE" terminal because that's an old ski. (Pre-MPEM)
