AKnarrowback
Has anyone tried or seen a system that will make full up to full down trim changes happen fast? I have seen lever operated nozzles on youtube for stand ups and was thinking of building a system into my 94 XP.
I'm thinking of linking in a short cable from a hand lever into the stock cable at the trim motor mount.
I only trim full up to do tail stands at low throttle so I'm guessing the lever idea can over come the nozzle thrust. I know the thrust will stop the nozzle, using the stock motor, from trimming up as far as I modded my nozzle to do. I'm using that knowledge to assume the nozzle will hold a steady, straight back level, setting when the lever is released.
Lots of things to work out with getting full nozzle travel out of a hand lever, leverage vs thrust, building a cable mount and tying the cables together somehow.
Any experience out there on this idea?
