HI Lance
I looked around and the stator looks the same as used in many motorcycles (XR600 etc ). So if you get stuck and auto sparkie should be able to give you some pointers,
It was pretty easy, stripping the wire is the hard part. When youve got it stripped back to the iron core, you need to make sure there is an insulating layer before you start rewinding. I used electrical tape where the base layer of resin came away when stripping the wire. I used1mm transformer wire ( I bought three 14m rolls from Jaycar electronics, the bobbin made handling easy ), cost about $11 each.
If you search for stator winding images on google, you will see how to do it. Every third pole makes up one winding. Each post takes about 10 min to wind by hand I counted about 35 turns on each post( you have to do this 18 times, so dont hurry), be careful not to scratch the coating of the wire, and dont hurry.You need to wind as tightly as possible, as the first and second circuits are easy, the last one is difficult as your starting to run out of room.
After you wind each post, stop and use an ohms meter to test if youve got an accidental short to ground.
Once youve wound it, you need to encase in resin, so the wires dont rub each other and short out. I used plasticast ( 2 part resin), from an electrical wholesaler,( ive been told i could have used RTV ) you need to let it go off a bit as its hard to work with when its like water, but good for getting in to all the gaps.
NOTE, make sure you leave enough room where the three retaining nuts go, there need to be able to be tightened without catching the winding wire,
Good Luck
DO NOT HURRY I took my time and it cost me $50-$60 NZD, dealer in NZ quoted me $1058 NZ ( or $3-$400 ex ebay ).
