G Greg Moore Member May 28, 2018 #3 You can use any high end synthetic meant for wet clutches. Motorcycle oil is common with a lot of S/C'd seadoo owners.
68ragtop Well-Known Member May 29, 2018 #4 I have been running Castrol 4T motorcycle oil. Valvoline also makes a good wet clutch 4T oil. I do not run synthetic in the supercharged skis. Last edited: May 29, 2018
Digdog Active Member May 29, 2018 #5 Seadoo recommends their oil because of the slip in the clutches, non synthetic oil is not a good idea in these engines because of the bearings inside the supercharger are spinning at 5 times the engine rpm. Last edited: May 29, 2018
