GreenChevelleSS
I have 2 Seadoos One is a 2001 GTX the other is a 2003 LRV
They both have the Rotax 951CC 2 stroke engine.
The LRV runs great for about 20 minutes then the all of a sudden it starts throbbing or pulsating, cuts on and off, whatever you want to call it at 3/4 throttle or higher. Its acting like you let off the throttle then hit it full agian and then let off etc. It looses about 800-1000 rpms when it does it. The more you ride it the longer it looses the power.
The fuel filter was cleaned, plugs changed, oil filter changed.
Any Ideas on what could be happening?
Water in gas?
The GTX is having a worse problem. You can ride it for about 20-30 minutes then all of a sudden it dies and wont start back up until you take out the key and put it back in then its hard to start but will. Then if you go anything over 1/4 throttle it will die with in 30 seconds but if you stay below quarter throttle you can cruise around for quite a long time.
Its very wierd thinking the fuel pumps might be causing some problems as well because it takes a long time before the fuel filter bowl to fill up as compared to the LRV.
Water in gas?
