deepdiver
I am working with one of my '95 SPX which had a lot of water in bilge last time out and also cavitating. Time to replace seals and wear ring I think. Shaft is spinning OK. I took off rear and tried the "tree technique" but didn't have a come-a-long so tried a web based one which failed. Next up was the 2X4 block after getting some 5 1/2" bolts from NAPA. They have only pulled it out about 3/16" and I am close to end of travel. What the heck is holding on? I have removed the internal hoses which fittings seem to be siliconed in. Do they pull thru?
Next up is to hook back up to the tree with a chain to the 2x4 and jerk it from my truck. Should it just pop out? Is this a dangerous method?
I am open to suggestions. THNX.
